How does this work- lighting
Well, my list is getting much more manageable, not that I have a lot done but at least understand what I'm dealing with better and chipping away on the list! I brought the boat home last night to do some real cleaning but want to keep focused on the other tasks as well. We have a trip Mothers day weekend from Sanford Fl. Lake Monroe up the St. Johns to Palatka which is pretty much an all day trip with the speed zones and stuff....anyway, I'd like to get a handle on my lighting and this is a subject I have brought up but never really got any answers on......and I was thinking this morning if I knew better what was supposed to work when, I might stand a little better chance of resolving the issues. If I know what switches are supposed to work what, I sure would have a better chance of figuring this out, at least a starting point that I don't have right now.
as far as what does work, with regard to lighting, I'm not talking about cabin lights as they all work fine.
What is not "working" are my running lights and my spot light. The lighting has not been a big priorty as we have not stayed out on the hook. I am a little concerned about the trip as we are not planning to be doing anything at night but the trip goes through some remote areas and if I or someone else breaks down, we may be boating at night or dusk unplanned.
When on shore power or on battery when I hit the switch for the courtesy lights, I have two lights that come on in the upper deck area. Is the light on the back of the rear seat that would shine out the back of the boat supposed to come on with that switch?
My at anchor light on the top of the arch does seem to work fine, and that is a white only light, correct? And just the one light is required at night while at anchor, correct?
Now on my running lights, it just occurred to me this am that perhaps those will not work unless the ignition is on? Will they not turn on when just on battery or shore, does the ignition have to be on? Right now none of those come on but have not tried with the ignition on....now I know it's easy to say try it (and I will) but if I try it and it still does not work I'm still not sure what the problem is and there sure is a crap load of wiring to try and trace it down so knowing how it is supposed to work is key here. Also, from looking at the required while under power lighting, it looks like the light on the back of that rear seat mentioned above should also be on with the other running lights, correct?
On the spot light, again, does that light only come on if the ignition is on? I would not think so but assume that is a real energy eater and maybe that's the way....I have checked the switch at the helm and it seems to have power ok but the light does not work. The remote control operates and the light moves but no light. From the survey, the bulb is a two function, flood and spot? When the fellow did the survey, one of those functions was working but I can't get either and again, just thought about the ignition being on and have not tried that.
The last item is the windlass- I spoke with Randy Rinker yesterday (anyone figure out how to get spell check to recognize the word Rinker without showing it misspelled? After all, it is a Rinker site!) and he advised that glass I have been fighting should come out without removing anything and the trim should have been installed first and then the glass put it...well, mine will not come out, there are no panels that pop off so it looks like the headboard or top piece of trim will have to be removed to get the glass out. I might give that a whirl this evening as I suspect there is a fuse or connection issue at the motor as it just has not been used. I have checked the power at the helm switch and it does have power there so it's something from the switch forward being the problem and getting behind the glass should resolve that issue!
Thanks for the input as always!
Rasbury,
Your ignition does not need to be on for any of the lights to work. The light at the swim platform pointing to the rear works on its own switch from the helm. It does not come on with your running lights. As for your running lights, the switch that turns on your anchor light on top of the boat is a two way switch. I believe down is for the anchor light and up is for running lights. When you turn on the running lights your dash lights will come on as well. If they don't, there is a dimmer switch that adjusts the dash lights that might be turned down. Your windlass also has a lockout switch which is right below the toggle that operates it. You push in the red button to adjust to on or off. This is to ensure that nobody leans into the windlass toggle switch and accidently drops the anchor by mistake.
Hope this helps.
I don't think your rear light has anything to do with navigation. For navigation, all you need is the front colored lights and the light on top.
Power vessels less than 12m may show a single all-round light in lieu of the separate masthead and stern lights.
I bet you'll find corroded connections at the bulbs / burnt out bulbs. If corossion, put new bulbs in with dielectric grease on the connection points.
A good anchor light at the highest point remains lit all night when on the hook.
Bd has your answer about why you don't have lights. Corroded/bad bulbs/connections all around. I'd do 'em all. A serious hand held spot and backup vhf radio are always at my helm after sunset. The bow spot is great but back ups are important because as has been said by better captains than me "If it's gonna happen, it'll happen out there".
Mike
If the motor turning your spot light is working you are getting juice to the light, check the bulb.
If you have checked the circuit breaker for the windless (it is on the dash some where) and the motor does not run (up or down) there might be some corrosion on the brushes and armature of the motor. This was the case on my boat because it sat on the water for a long time before I bought it. If you find that you are getting juice to the windless but motor does not run it is time to pull the motor. If you need some help pulling the motor let me know because I have done it on my boat. I can be a PIA with some help.
Oh everything Hamdog said about the switches is 100 percent correct. Get a cheap voltmeter from Harbor Freight ($5.00) and chase down the wires to see if you are getting voltage to the item that don't work. Or ask someone with a little electrical experience to help you.
Len & Robyn 342 FV Freebird
