Outdrive Trim system problem
Ok fellas thinking caps on. 2003 310 fiesta Vee with twin 5.0 mercs. Toward end of season trim button when trimming with throttle button was acting funky. Jumped in and when trimming up only starboard drive moved. Used trailer switches to trim the drives for rest of season. When I pulled boat for season tried seeing what was going on, starboard would raise up to limit then the port would start up and go to limit. With both drives trimmed up to limit both would come down together some times and individually other times. Trailer switch only picks drives to trim limits. Any ideas?
Post edited by Pat310 on
Best Answers
reneechris14 Member Posts: 3,134 ✭✭✭✭✭
I would try swaping solenoid maybe power or ground. Cheap part and nice to have a spare, same one for starting on the manifold.2005 Rinker FV342 Pawcatuck river,Ct -
LaRea Member, Moderator Posts: 7,848 mod
Also check that the power and ground connections at the pump are clean and tight on BOTH pumps. Maybe a bad connection on the stbd pump means it's pulling down the voltage more than it should. -
YYZRC Member Posts: 5,264 ✭✭✭✭✭
Override the trim limiter by disconnecting the bullet connectors at the transom and connect them together with a short wire. Test. That will rule out the senders before you go dumping money into the pump or binnacle.2008 350 EC on Georgian Bay
You probably have both pumps connected to the same battery. While the stbd is trimming up, it temporarily pulls down the voltage. If the port pump has a loose or corroded connection on power or ground, maybe it can't get enough power until after the stbd pump finishes.
Can you trace the pump wires to see where they get power and ground?
