Outdrive Trim system problem
Pat310Pat310 Member Posts: 582 ✭✭✭
edited December 2020 in General Boating Discussions
Ok fellas thinking caps on. 2003 310 fiesta Vee with twin 5.0 mercs. Toward end of season trim button when trimming with throttle button was acting funky. Jumped in and when trimming up only starboard drive moved. Used trailer switches to trim the drives for rest of season. When I pulled boat for season tried seeing what was going on, starboard would raise up to limit then the port would start up and go to limit. With both drives trimmed up to limit both would come down together some times and individually other times. Trailer switch only picks drives to trim limits.  Any ideas?
Post edited by Pat310 on
Best Answers
    Answer ✓
    I would try swaping solenoid maybe power or ground. Cheap part and nice to have a spare, same one for starting on the manifold.
    edited December 2020 Answer ✓
    Also check that the power and ground connections at the pump are clean and tight on BOTH pumps.  Maybe a bad connection on the stbd pump means it's pulling down the voltage more than it should.
  • YYZRCYYZRC Member Posts: 5,226 ✭✭✭✭✭
    Answer ✓
    Override the trim limiter by disconnecting the bullet connectors at the transom and connect them together with a short wire. Test. That will rule out the senders before you go dumping money into the pump or binnacle.
