Battery Charger
I've purchased a 2008 Rinker 280 Express cruiser with a Merc 377 MAG engine. Purchase was done late in the fall based on a quick sea trial and a marine survey. The boat is currently several hundred miles from home and shrink-wrapped for winter, so I cant access it. Could anyone tell me if there is an onboard battery charger on the boat as standard equipment for this year and model.?? I've been researching new batteries for the boat and just discovered that I cant find any reference to a battery charger and dont see one in the survey pictures. I guess I just assumed there would be one. Thanx for any help and info.
Best Answers
Cableguy Greg Member Posts: 5,053 ✭✭✭✭✭
I also have a 2008 280 EC. Yes there is an on board charger. It is located on the firewall between the engine room and the cabin. It is made by Progressive Dynamics and should be the PD2020 model. I had some issues with mine the last few years, so I replaced it with a ProMariner ProNautic 1220P charger. It is a 20A charger and is able to charge 3 banks of batteries along with different style batteries. I have the Duracell Group 31 batteries from Sams Club on my boat and it does a great job charging them. If you have any questions or issues, feel free to reach out to me.
Go Steelers!!! -
davidbrooks
Member Posts: 1,416 ✭✭✭✭
Also recomend the Duracell Group 31 batteries. I think i keep the Sams membership just for the batteries.It's 5 O'Clock Somewhere! -
mattie Member Posts: 1,322 ✭✭✭✭
Hey Seahawk,
Great forum here for these types of questions.
Just a heads up, be careful of program settings with onboard chargers - they need to be set for specific battery types. Lead-acid, AGM, etc. they all charge & maintain at slightly different rates. Dealer told me about the numerous times that AGM batts are toast after one season because the owner never changed the settings after upgrading batt types.
I've gone down that road a couple times swapping out battery types. Now I'm back to traditional lead-acid. They work very well - if you treat them well. Cost less/replace more often.
my2cents
https://www.instagram.com/tv/CGxahB1p5P0/?igshid=1rzonvvmws8bg
