Strange Fuel tank usage
pcmpete
Member Posts: 114 ✭✭
2010 360 EC. My starboard fuel tank level drops more that the port side. Is this normal or what issue should I look for?
It is not VV display issue, the fuel dock pump confirms it.
It does the same even if I don’t use the generator.
Each tank valve is fully open and cross feed valve is fully open too.
Any ideas???
Any ideas???
Thanks
You have VV? Is one engine burning more fuel GPH? This would be a different issue.
I am not completely familiar with your fuel system but others on here who are familiar will have other info for you.
Apparently I suck at the clarinet 😂
I hope this is not a silly question, but if it should be closed why is it where ? I am new to twin engine and twin tank setups.
