kaboom, says the boat...
A 28' boat joined the driftwood in morehead city north carolina, at the morehead yacht club this weekend.. not cool..
He had just topped the tanks, and couldn't get it started... The dock hand had just left to retrieve a charger, and the two on board kept cranking the engine trying to get her to fire up... Well.. she fired up.. they didn't die, but they may be wishing they did as they are in the burn center today...
I pass this to you guys kinda tongue in cheek, because that's just my personality, but friends, there is not a dang thing funny about this.. these two were and are mighty lucky to be counted amongst the living today.. their boat is no more.. it could have ended a lot worse..
For the love of all that is holy, use your blowers, and don't excessively crank an engine that is flooded... If you flood, go full choke and only hit the starter, don't ride it.. better yet, sit back and do some rope maintenance or scrub your deck.. let the vapors dissipate.. open your engine compartment and let her breathe.. don't go kaboom..
By the way, when I say bump the starter, I don't mean consecutively back to back.. I mean hit it for no more than two seconds and not again for at least a minute.. every time you hit it you're generating a spark.. you don't want things hotter where the heavier fumes rest and your starter lives than need be.
Post edited by 212rowboat on
http://www.wcti12.com/news/multiple-injuries-reported-after-morehead-city-boat-explosion/25791388
the story, now better explained than what i heard on the radio, isn't as bad as it sounded... the boat is in surprisingly good shape afterward.. still, both dudes went to the hospital, and one was airlifted to another hospital..
I hope they post the results of the USCG inspection.. just curious..
Not being morbid, but knowing the cause is good for everyone else. One hopes they didn't fuel up a rod holder or similar. Luck it did not completely burn and take the marina with it.
A guy at a marina south of me was filling his boat from a plastic fuel can out of the back of his P/U to save a few bucks..took out several boats and severely injured him too.
[-(PC BYC, Holland, MI
You're supposed to run the blowers 4 minutes after filling up with gas, but most people are probably much less than that.
Good guide - http://www.boat-ed.com/ri/course/p2-2_fuelyourboat.htm
I like to error on the caution side: I'll run the blowers from the time I get on until I have everything set and ready to go and then start/warm up, so 15-30 minutes at the dock. Hurts nothing. I also run them when at no-wake running too. The only time I have them off is when running at cruise speed..unless I forget to turn them off
