232 captiva bilge issues
I have a 2000 232 captiva. When i pull drain plug I have water coming out of hull which my bilge pump will not pump out. The floor under engine is dry so i assume its a double bottom hull. The bilge pump is on this floor directly under engine. Recently purchased this boat and see no pump to extract water between the double bottom. Very confused and concerned about sinking this boat while moored in the water at the marina.
There is a thread on the forum about folks who have rigged up supplemental pumps to get every last bit out. That's a personal preference.
The question is, do you have too much water in your bilge during normal use which may indicate a leak or water from another source.
Does your bilge activate regularly - or do you need to turn it on while on the boat due to excessive water? That could indicate a potential issue. If it's just a nominal amount after a ride, probably nothing to worry about.
