Plumbing a macerator pump for home pump out
Stever00
Member Posts: 145 ✭
Anyone set up boat for home pump out to to sewer?
I trailer boat to smaller lakes. Not even sure where a pump
out station is. I bought a Seaflow 12 volt pump. Thought I
might use it to pump out from outside at pump out opening.
These pumps don't seem to strong. Don't wanna cut any holes
In boat. Does pump need to be close to tank or below? Could
I install Y valve and pump through hose out back? Would a transfer
pump work? This is a 240 Fiesta Vee. Has type 3 holding
tank.
tank.
I have one on top of the poo tank. I have the second one plumned inline to the over board line that you can use 3 miles off shore.
Im using a brass 3 way valve to make the connection to the suction end of maceraror number 2 located in my engine bay. Mybmacerator #2 has a clear heavy duty vinyl extension hose I uncap to attach a garden hose. I feed the garden hose from my engine compartment over the eude of the boat to the pump out hole in the ground. My boat is tall so it's a good 20 ft of those.
At that point I climb my ladder and turn on the hose at the wash down so I have clean water going.
I maks sure my 3 way valve is turned to feed macerator number 2.
I then prime the first macerator until I hear her start pulling the pee pee poo poo water. I at that point cut on pump number 2.
I keep the 2 pumps running until i hear them lose suction. At that point i kill the motors
I then turn them off and pump some fresh water down the factory supplied pump out waste connection. I fill it for a minute or three. I then repeat pump out. I do this 3 or 4 times until the water coming out of my macareror #2 looks clear...or at least less brown depending on how busy they are. At the end of the season I did this about a dozen times before winterizing.
Its a gross process but better than dumping a porta potty. I had one macerator fail on me last summer mid pump. Was the one sitting on top of the holding tank. It was awful to replace. I actually consider forcing the family to change their dietary habits to make the situation better when it happens again.
Now I think ill just put in 2 new macerators every 3 rd season.
You may be ok with using one macerator but I didn't want to chance a clog with the height of my boat. Some have used a macarator with a rubber boot as a gasket to go directly from their pump out fitting. Mine would not pick up from there, it just blew out stinky air.
Good luck and just keep telling yourself, everyones family poops.
PS don't do this project just after eating. You'll more clean up to do.
Unlike my previous post, law enforcement officers do not have a sense of humor on this topic.
