2008 280EC Battery question
I just launched my new to me 280EC last evening. When I got to the ramp, I put the battery switch in the 'on' position and the boat wouldn't fire up. I changed it to the 'both' position, and it fired right away. Took her to the slip, shut her down and connected her to shore power. She wasn't on shore power all that long and the admiral wanted to head out on our maiden voyage. Before I went out, I switched back to the 'on' position. We were out for a little while, anchored the boat and I never shut down the engine because I didn't want to get stranded. While on the hook, we had all of the cabin lights on, had the swim light on, along with the radio. At one point, the radio shut off. I wasn't paying it any mind until I had to raise the windlass. It wouldn't come up due to no battery power. I then switched to 'both' and everything came back on, windlass worked. The question that I am getting at is which batteries run with the switch in the 'on' position? I am guessing it is the house batteries. If it is the house, do those batteries run everything at the helm as well? The house/starting battery thing is new to me. My previous boat was a 232 cc with 2 batteries, but they were connected to everything.
Greg, what rpms was your engine running at when you flicked those switches? Was your shore power also plugged in at the same time?
If the engine was idling and the shore power was plugged in, this is what I'm guessing was going on.
Your alternator will not charge unless your rpms are up closer to 1000. Below this, there's not enough power to run the alternator, so if it was idling, the batteries weren't getting any juice from the alternator. The switches should simply turn on the shore power (110V) to the battery charger so that it can charge your batteries. The battery charger produces 14V and energizes the electrical circuit (so even if you have a dead battery, the charger is pushing amps out to the 12V circuit that battery is on).
My guess is that you have a dead crank battery (won't hold charge). My guess is it may be because the shore power charger switch was off, and the battery was damaged in the process because of being drained too many times (need to keep these batteries topped up for crank batteries to hold life). Deep cycles are way better as they can discharge munch more current before they are damaged (so in effect, they lasted in between motor runs, when they were charged via the alternator, whereas the crank battery didn't).
I am finding out that cruiser life is different from cuddy life. In the end, the reward is well worth it. The admiral and I are very happy with our purchase.
