No helm lights
Hi All, new to the form 2006 320 in CT, all of my helm/dash are not working except for the depth finder. I have pulled the the dimmer module and still no lights. Pulled the dash and switch and found that one of the terminals has no wire going to it.
  • LaReaLaRea Member, Moderator Posts: 7,922 mod
    Hey, welcome to the forum.  I'm pretty sure that's normal wiring ... most switches don't use all eight pins.  I'm guessing you already know this part:  to turn on the helm lights, turn on the nav lights and then press-and-hold the "panel lights" switch up to adjust brightness.
    The depth finder may be separate as it is digital so maybe the light is always on? And yes as larea said make sure you press up on the dinner to brighten the lights.
