Volvo 5.7 GI-E Backfiring at 3100 RPM
echandler1971
Member Posts: 231 ✭✭✭
Sorry for the rambling and sometimes repetitive nature of this. Typing this on an iPad really makes putting thoughts in words harder.
So, we closed on our 05 350 FV and on her maiden voyage from the storage marina to her new home, we started to get backfiring on port engine at 3100. That was only after a terrible problem getting it started after she was dropped in. My mechanic had done a tune up on the spot when the engine wouldn’t start, replaced fuel pressure regulator and tested fuel pump. He claimed that the port tank had bad gas and charged me $1100 for parts and labor and told me to have the 80 gallons pumped out. Still he got it started so we left it running and took off. As soon as we tried to get on plane, the backfiring started.
The twin engine runs fine. Before a logistical nightmare of having a tank pumped, I tried an experiment - isolate both engines to the starboard tank. Experiment failed. Port engine still backfired. See video below. How, if using the exact same gas, one engine backfires and one doesn’t? It didn’t add up and I wasn’t spending more money on the mechanic.
Here is what I did after that:
1. Emulcifier in port tank - could be water due to ethanol over winter storage - done before my experiment so kinda irrelevant
2. New port fuel filter - was old full of water? High RPMs could splash over
3. New port ignition coils - theory that at high RPMs possibly it’s not providing enough amperage/voltage for a hot spark
4. New injectors- South Bay 8-pack. Could have a leaky injector or bad spray pattern or spray volume in a cylinder. Plan is to ship old ones out to get tested, cleaned and be ready to use in other engine as as set tested together. I used a YouTube video to replace them. Very helpful.
Boat came with a brand new spare fuel pump, which I guess I could try next if my work fails to fix it. Anyhow, engine was purring at the dock on a stormy yesterday. We’ve been battered the past few days. I got her up to 3100 no problems but no load. It’s the load that will really tell if it’s fixed. Memorial Day will be the big test as weather will be favorable.
I sorta threw money at this because the Admiral had lost all patience with our expensive floating camper I purchased, but saved some money by doing the work myself.
https://m.youtube.com/watch?v=vOIiQTr6dzE&feature=youtu.be
Dan of Steel
'05 Rinker 360 Fiesta Vee
Post edited by echandler1971 on
If it still didn't run well after a few hours I would check fuel pressures with a gauge you can borrow from most auto stores. Low side is something like 15 psi and high side is maybe 30-40. You can Google it and you should be able to find it easy, I know I'm not accurate enough to use those numbers for testing. Paint chips in the fuel system can be an issue from the painted interior of the pumps but it sounds like you may have eliminated that.
How many hours on these engines?
Did you check the plug wires, you can do a resistance test on them?
Does this engine have a cap and rotor? That may be a point of failure. Can't remember if that year had electronic ignition.
Unfortunately those paint chips will come off and go straight to the injectors however he did the injectors and issue remains so not sure that's the problem.
matt
Ran her today up to WOT and no backfires with new ECT.
so I start swapping parts from one motor to the other, coil, IAC valve, fuel pump assembly, cap and rotor, checked spark on each cylinder. Still back firing at higher RPMs, guy at the marina who is a decent mechanic thinks it valve train related and either a valve sticking or the cam is shot, he suggest to put a vacuum gauge on it to confirm it has a valve train issue. Once the vacuum gauge is installed and motor is running the vacuum is stone cold steady but a little low(14.5 in) at idle, he suggest rotating the distributor to try and increase the vacuum, I am reluctant because I set the base timing last year and can see the spark advance on the fox marine app. but I figure at this point what the heck. So I get the motor started and it is at idle, loosen the distributor and turn is a little each way, nothing, then I turn it till it’s stalls. This is kind of how I thought it would go but wasn’t sure so we rev it up to see what the vacuum gauge does at the ramp it was backfiring at, now it won’t backfire at all. I tightened down the distributor and tried it out two or three more times and still no backfire.I guess the distributor shaft has developed a slight amount of play and that is what caused it to be out of time and the slight adjustment we made solved the issue?
all and all I am happy to have it apparently fixed but and a little nervous for this weekend.
I put all the parts back on the starboard motor and it is also running correctly.
I am hoping it all stays this way...
