water puddling under radar arch ?
My 2006 rinker fiesta vee 30 ft . Canvas is not attached to the arch on this model . Seems the canvas is drooping a bit . Every time it rains water puddles in the center between the arch lights . Is there a adjustment in the poles or is my canvas just old and stretched  out. still seems in good condition
  • RustySRustyS Member Posts: 83 ✭✭
    I have the same boat and when I purchased back in 2017 the PO had an extendable boat hook with half a tennis ball used to prop the bimini to prevent ponding. Needless to say I learned what that was for the first time I forgot when it rained.
    Just replaced all canvas this year and the factory OEM purchased through TJ is much tighter and all water runs off as it should. Very happy with that!!
    There are the push-pin adjustments on the rails to tighten; I assume you probably already have them in correct position.
    Probably just stretched out....
  • garyartersgaryarters Member Posts: 3
    canvas still in good shape , so I guess I continue to put up my boat hook when rain is coming . Thanks
