Transom leaks
Does anyone have tech drawings of gaskets , thru bolts between 6.2 merc and B 3 outdrive. 2006 270
I have leaks and at first shop suspected Y pipe ,
The problem I’m told can be gasket , thru bolts or transom.
Thanks in advance.
    Thanks in advance.
    Welcome to the transom leak club.
  • LaReaLaRea Member, Moderator Posts: 7,946 mod
    @Jmifsud I sent you a private message with the Merc installation manual for your sterndrive system.  It has the information you need.
  • PickleRickPickleRick Member Posts: 4,243 ✭✭✭✭✭
    edited June 2021
    I also like the exploded view parts diagram that anyone can access using your engine/drive/housing serial numbers.
  • J3ffJ3ff Member Posts: 4,180 ✭✭✭✭✭
    Thanks in advance.
    Yes welcome to what I went through for 12 months.
    Had everything taken apart and transom hole redone, new gasket + sealant. 4000 dollars later no water enters the boat.. but now we're in for a whole other problem.
  • JmifsudJmifsud Member Posts: 13
    oh wow , leak stop ..... what’s the other problem?
    If it's leaking from the steering pin, you have to remove the transom assembly.  If you're lucky and there's no corrosion, you can replace the steering pin.  If there's too much corrosion, your only solution is to replace the transom assembly.  Either way, it's expensive, so I hope it's not the steering pin.
    edited June 2021
    There is a steering pin repair kit out there that doesn't require engine removal to install.  Im not sure it's the most popular method.
    Thank you for your comments.
    marina way to busy at this point .
  • YYZRCYYZRC Member Posts: 5,363 ✭✭✭✭✭
    How bad is the leak?
    Also, is it possible to remove the drives and loosen the transom assembly to reseal without removing the engines?
