Lower Voltage when engine is running
pcmpete
Member Posts: 114 ✭✭
Situation.
Ignition off
Battery is 13.2volts
Engine off, ignition on:
Battery is 13.0volts
Vessel View is 13.0volts
Engine Running
Battery is 12.8volts
Vesselview is 12.4volts
even if the alternator is not exited yet, why change is voltage readings while running?
Video 1 - Starboard Battery with Starboard engine Start
Video 2 - Starboard Battery with Port engine start
Ignition off
Engine Running
but why the difference between battery and vesselview only when engine is running
