fiesta vee 270 ,does it spit water all the time when a/c is running?
Hello,
Wife and I are new to the marina life.
new( used) boat in really good shape.
Wife freaked out and does not want to run a/c,after seeing the discharge.
Can this ever end up in the bilge on intake?
thanks.
thanks.
Welcome to boating.
To help put her mind at ease, put a garden hose in the bilge and turn it on. Let her see how easily the bilge pump keeps up with it.
Welcome to the forum!
You should explore your boat and see what each thru-hull fitting discharges. That way you will know if you have potential trouble or not.
Some are for A/C, some are for bilge, one is for the shower, etc.
For example, here is a diagram I made for my boat so I know the source of each thru-hull...
Folks leaving the a/c on all week with no problems(not something I would do)makes us brave against a broken line.
Having the unit shut down before sinking the boat, is also a plus.
Question..?
does the a/c unit pump spit water out ,on an ongoing basis?
when a/c is on and working..? with no breaks?
or does it cycle?
Thanks..
slept on her for the first night...it was a bit warm.
great diagram thanks!
Just because you have the AC off doesn't mean that line can't break and still let water in but as others have said the bilge would keep up with it and pump it out. Those lines are thick rubber lines with reinforcement in the rubber if I recall, such as string I guess you could say. There is no reason to sweat the night away for fear of the line breaking. If you are that concerned then you need to close all your seacock valves as that stops the water right at the source.
You can set it so that the fan runs constantly. I think it's more comfortable for sleeping on the boat. On MarineAir units, you can change that setting from the keypad.
Marine AC units have been proven for decades in many thousands of boats. The risk is extremely low. I regularly leave mine running unattended for a weekend. When I go on a 10-day cruise, I run the AC any time I'm connected to shore power. I turn mine off during the week, but that's only to avoid wasting power.
I sleep good tonight!
this weekend.....on the boat ,WITH...the A/C running!
whoo hoo...!
Thanks guys...
max
the little lady thanks you as well!
I get to be the.... deck hand .
I am teaching her everything about the boat,just in case that captain role,is thrust upon her.
hopefully,that will never happen.
The current ac pump is 1200 gph ( https://www.amazon.com/gp/product/B006YGLRBA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 )
The bilge pump is 1100 gph.
That wouldn't be great. Unless somehow there's a port that would allow water to go to the rear as well.
Bought this one a few weeks ago to have it ready to go to replace the current pump when it wears out (plus the current one makes a hum I don't like)..
https://www.marinaire.com/pump-p/mfp300kt.htm
Might have to get that swapped out sooner rather than later.
