DC System "grounds" check
I have digital displays and they just started cycling off then on real quick at engine start up. I have checked a couple sources and it seems this is not normal for my set up and there is likely some low voltage issue, hopefully a simple one. Batteries are new and exceed the min CCA. So I have been told to make sure the grounding is good.
After some online research in to what checking ground really means, it looks like for DC "check your ground" really means make sure all is good and clean with the black wire battery connection at the battery. Make sure zero volts between the post and connection. Then chase that to check the same on the starter, but that battery connection is really important
Sound right?
Sound right?
Most Rinkers have a single ground terminal block and the wires are not labeled, but your boat might be different.
Gramu to your point, the electronics are on house batteries so they don't restart at start. This is just my 4" Volvo digital displays that restart. I turn the key to "on" and the displays come on, show 0 RPM, wait 5 sec, then when I turn to "start" and starters engage the displays go off then back on real quick. Used to always stay on.
I will check all of the connections in the pic and on the batteries. Also LaRae it is pretty easy for me to get in to the helm to check for an additional block there.
Batteries are brand new but I may run them to Auto Zone for a load test anyway to be sure.
Open to any other thoughts, thanks!
yes Gramu I can hold the meter on the battery while the admiral fires them up but I don’t know what I should see. Looks like automotive should not see less than 10.8 or 10.9 while starter is engaged?
so I am really questioning these brand new batteries. I had thought that I should be in the upper 9s while starting and preferably 10.5 volts.
thoughts?
both batteries tested good at auto zone and o Reilly’s. I then really cleaned up all battery connections which didn’t seem bad but now look great. I also tightened all grounds.
I am getting 10.8 volts while starting when holding the digital meter right to the battery posts which is pretty good. Did not try the starter.
also still can’t replicate the problem
