Engine Hatch
Hello Everyone. I have a 2004 Rinker 342 Fiesta Vee. The rocker switch to open/close the engine hatch does not work. However, the manual lugs located at the stern of the boat works to open/close the hatch tell me that the hydraulic lift works just fine. I assumed this was just a bad rocker switch. But I replace the rocker switch and it still does not work. Any advice?
Thanks in Advance!
Thanks in Advance!
Look in the engine room for a screw terminal attached to a wall or bulkhead, with about 50 black wires attached to it. First, make sure every screw is tight. Then, methodically give each wire a solid pull and make sure it's really, really solid.
If you find anything that is even slightly suspect, rewire the whole thing. I can provide guidance on tools and supplies. Easy DIY.
@Cableguy Greg there were actually about 5 things acting up from various parts of the boat. I was just trying to fix this problem first (engine hatch) but perhaps in hindsight I should have mentioned the other problems.
@LaRea Your schematic above was very helpful and allowed me to trace the two wires from the switch all the way to the ram. The problem was those connections were all fine. But then per your your post on July 12 I decided to trace the negative (black) wire as far as I could. Didn't take too long from there. Found a bad connection within the connector. The was a ground wire being used for several different things...fixed them all.
Thanks again guys. I really appreciate all the support.
