Cooling system anodes problem
Steve1980
Member Posts: 6 ✭
Hi All
I wondered if anybody has come across the problem that I have.
I have twin Yanmar 4lha-stzp 240's in my 342. The boat is kept in Fresh water on the River Thames and used in salt water very rarely. The oil cooler failed and insurance company refused to pay out due the engines cooling system had ZINC anodes fitted throughout. I have searched everywhere and can not find Magnesium anodes for the engines. Even speaking to Yanmar they say they have never supplied any and couldnt find a 3rd party that can either.
Also the engine anodes have never been removed since new in 2002 as they still have the original factory paint marks on them, I am currently trying to claim through my Surveyors insurance as this was not picked up on the pre-purchase survey a week before the cooler failed, in theory I have a boat that I shouldnt be keeping in fresh water, not to mention voiding my insurance should anything else happen....
Totally confused and gutted as I love my 342.
https://martyranodes.com/products/
The core can not be took out as it is a sealed unit however you can see oil from more than one of the holes and for it to leak so bad makes me think it split with ice as surely corrosion would cause a pin hole and slight leak to begin and get worse over time with which would be noticeable.
From what I can tell the engines internal cooling is a closed system with antifreeze that runs through the heat exchanger, then it has an additional cooling which is open which is pulled from the river or sea ran through a strainer, then pumped through oil cooler and out the exhaust, there are anodes in the pump and oil cooler.
@ Dalek, thanks
