Chartplotter Ideas
Thinking of replacing our older (2011 I think?) Raymarine Hybrid touch with something a little newer. Looking for the "most" simple, basic unit that will give me what I need. We're talking pre-school level here. Not interested in fancy gadget, gizmo style stuff with thousands of features. As long as it gives me an accurate map and depths mostly everything else I can get on my phone. Any advice would be appreciated.
Thanks in advance
Thanks in advance
Can still use traditional sonar for finding the fish. I usually use my clear vu for scouting where I'm going to drop my anchor. I look for down trees, stumps, etc that I could lose my anchor on.
This model is sub 400 bucks so it won't break the bank. I found this model on nearly every boat I've rented and the tracking is great and charts perfect for navigating skinny waters where prop/foot/skeg damage is a regular occurrence.
The chart plotter is equally useful for marking your destination. Keep in mind the plotter will take you in a straight line across land so you'll need to navigate around safe waters unless you pin point the path.
Will also save points.
Can be flush or cash mounted.
Being its the common model on rental boats you know it simple...and affordable.
I would never advocate for replacing a real GPS plotter with an iPad but I will say this. I've ran my 3G/LTE iPad's next to several Furuno and Raymarine plotters over the years and the iPad is as good, or sometimes better, in location consistency than the plotters. You DO NOT need to pay for cellular service nor do you need wifi, I turn cellular and wifi off when running the boat, but you do need the 3G/LTE capable iPad to use it as a plotter. I use a RAM Mount and a waterproof case. Having both is great peace of mind.
The first year or two we went there I was glued to the screen.
Now I really don't use it unless I'm heading out to an unfamiliar spot, we usually try to explore a new spot or two every year.
The last marina we rented from had a stack of damaged props, maybe 20 of them on display for renters to look at while doing their paperwork.
We don't get that kind of damage in our local muddy lakes and rivers
I second the secondary iPad for navigating if you're cruising. Being that I'm never more than an hour or two away from where I started so I don't feel the need for the redundancy.
@RiverRat232 we have run in 8-10 ft waves straight on the bow and while I dont plan to do it again, we were ok. We can do 5-6 ft from behind just fine. We recently went to cross lake erie in 5 ft close chop waves directly to the side and it was slam, slam and with 45 miles in front of us, we turned in for the night. Not worth breaking anything. We get off the lake for lightning of course. But we ran last month for 3 hours in the pouring rain and 2-3 ft waves on the port bow and were very comfortable. Had to turn the A/C outside down to 70 F though to keep the windows from fogging up
