Fibreglass Sheets/Panels?
YYZRCYYZRC Member Posts: 5,366 ✭✭✭✭✭
Is it possible to buy pre-made fibreglass panels? Rather than taking the time/effort to glass over a piece of plywood to make a panel, I’m wondering if there is a ready-made solution. Cosmetic, not structural. Need 1/2”.
  • PickleRickPickleRick Member Posts: 4,287 ✭✭✭✭✭
    edited September 2021
    Does it have to be fiberglass?  HDPE board  comes in 1/2.  No core to rot.  Can be bought at your local hardware store like Lowes in many regions.
    Also called marine board when you slap the extra mark up on it for the marine label.
  • YYZRCYYZRC Member Posts: 5,366 ✭✭✭✭✭
    Yeah I can’t use starboard as I want to glue/epoxy it.
    Can adhesives be used to bond King StarBoard® ?
    We are frequently asked how to apply and use adhesives with our products. We want to remind you that generally, bonding polyethylene with adhesives does not result in a permanent structural bond, like mechanical fastening or welding. Please determine the suitability of using an adhesive yourself with proper testing. Again, we do not represent these products, or make any claims about their abilities or accept liability for them.
    • If you need to use an adhesion process, make sure you have everything you need for the treating.
    • A sheet of one hundred and twenty-grit sandpaper.
    • A cleaning solvent such as Acetone, Toluene or Alcohol, and a propane torch
    • Your selected adhesive of choice and appropriate clamps to secure the bonded parts without damaging the finish of the King StarBoard®.
    • Proper surface preparation of your polymer is critical when using adhesives.
    • First, lightly sand the King StarBoard surfaces to be bonded with one hundred and twenty grit sandpaper. Now, clean the surface with a solvent, such as Acetone, Tolulene or Alcohol. Allow solvent to fully evaporate. Move solvent and other flammable liquids and materials away from work area.
    • Following the operating cautions of your propane torch, ignite the flame.
    • Working in a safe and well-ventilated area, hold the torch so the flame is approximately one to two inches (or two and a half to five centimeters) away and the blue, oxidizing portion of the flame is on the King StarBoard surface to be bonded. Pass the flame over the surface at a rate of approximately twelve inches (or thirty centimeters) per three seconds.
    • Total time the material should be exposed to the flame should be two to three seconds, about one half second per stroke.
    • This light exposure should not deform or melt the polymer in any way. You may see a “shadowing” effect as the flame passes across the surface, this is normal.
    • Make sure to let the polymer cool before proceeding.
    • Test the effectiveness of your flame treatment of the surface by wetting it with water.
    • If the water beads up like on the surface of a freshly waxed car, the treatment was not effective. If the water “sheets” or lays flat on the surface, like on an un-waxed car, the treatment was effective and the surface is ready for bonding. If you are unsure if the surface is ready, compare the water’s action on treated area with the untreated area.
    • For the best adhesion, bond the product within thirty minutes of treatment as the flame treatment is temporary and declines in effectiveness with time. If you get interrupted and cannot complete the bonding within an hour or two then you should re-treat the surface again before proceeding.
    • Then following the instructions from the adhesive manufacturer apply the glue evenly to the surface in a back and forth motion, generally hold back from spreading the adhesive all the way to the edge to avoid making a mess.
    • Apply the pieces to be bonded together, making sure they are positioned correctly then lightly clamp in place. Ideally wipe off any excess adhesive that may have squeezed out before it cures.
    • Let the bond cure for the manufacturers recommended time frame before removing the clamps.
    http://www.kingplastic.com/faq/
    Not that this will work for your application but my fillet table is built with hdpe that is glued together.
    I need to build out my dash a bit around the chartplotter. My goal was to find fibreglass that I could cut to fit and then epoxy the edges followed by a coat of awl grip.
    Ah I see.  I'd like to see what you come up with and finished product.
    You can use Kevlar
