AC Winterization
This is my first time winterizing my new 280 so I just want to make sure I'm not missing something on the AC system. I pumped antifreeze through the cooling water discharge hole on the port side of the boat and watched the antifreeze drain out the seawater intake on the bottom of the boat for the AC pump. Checked the strainer afterwards and it's full of antifreeze. That should be all I need to do for the system, correct?
