Trim Tab Question
All,
I've never had any trim tab issues with my boat until this weekend. Twice while I was underway, they stopped working for me. They are the lenco electric tabs. the switch with the little light indicators on it, just started fading out and kind of blinking, pushing the buttons did not seem to make the tabs move. One time, I got the tabs adjusted, and then the lights started blinking and going crazy again, but the boat stayed level, so i am guessing that they stayed where they were adjusted. this is my first experience with working on the trim tabs, so if anyone could give me an idea what all is involved in them, it would be great. Is it simply the switch and the tabs, or are there any other parts involved? Any inline fuses typically? Any details you can give would be greatly appreciated as I try to track down my problem.
Kneedeep, when you say it was a battery problem, you mean a starting battery or house battery was bad, or is there some sort of battery in the tab control box? I think all my batteries are good, both house batteries are new last year, and one starting battery is new this year. other one is pretty old, but engine still starts fine.
There is no battery in the control box, just works off your starting battery (or house, I forget).
The wiring is pretty straight forward..check the switch connection and the power lead that feeds off your ignition switch too. I think you can get the wiring diagram off the Lenco site.
I've seen the actuator box under the dash wiring, and I mean REALLY buried under it. I hate intermittent issues. I'll post what I find if I get motivated tonight.
Good luck and let me know what you find if you beat me to it.
I gave it a good cleaning but the tab feels like it's just about tired of carrying 4 or 5 fml spade connectors so I didn't push my luck. When that main switch tab fails it'll be lights out for the other items too. It'll come back as an issue someday but until then mine are back on-line.
Good luck with yours. Mike
I had my switch panel off this weekend for something unrelated to trim tabs. My tabs are not working now but they do make a sound when the I push the buttons.
Could it be that I knocked something loose or is it just coincidence?
Any other ideas where to start? Neither side moves up or down. Both sides make the sound when the buttons are pushed.
Ray
2006 390
Previous 2000 340
Might have knocked the ground loose
I believe they are electric/hydraulic. So if the ground or something was loose in the switch panel could they still make a pump running sound but not move the trim tab?
Ray
2006 390
Previous 2000 340
Not sure of your setup but I dont think that a ground would going to the switch. I would assume that the switch only switches the 12VDC. If you are hearing the pump run then the problem is not the switch. Like BD said check oil level......
Will do this weekend. Thanks for the help.
Ray
2006 390
Previous 2000 340
I had a problem with my tabs a few weeks back. they are Instatrim boat levelers and they are hydraulic. I had a leak in one of the cylinders. I refilled the tank with automatic transmission fluid and they worked great for 1.5 days, then stopped again with the tank empty. I noticed a small "oil slick" around the rear port tab when I returned to my dock. new hydraulics/lines are being replaced this week. tank was on the port side transom.
