8.1L 496 MAG - Air Actuated Single Point Drain Winterization
Squatch68
                    Member Posts: 62 ✭✭
                    Hello again folks
Update - After more research I better understand the system now. Its not actually pressurizing the raw water system, its only pressurizing actuators that open drain valves. I must have an airline that has come loose or a failed actuator. I will trace those lines out tomorrow. I think its best to just open the blue drain plus anyways, let the water drain out, then run anti-freeze through the system.
Original - I went to drain the raw water side of my 496 MAG using the single point drain/bicycle pump pressurization method. Followed the manual step by step. I could not get the system to pressurize so that the two green indicators would pop out. Pretty sure I could hear the air exhausting out of somewhere near the transom with every stroke of the pump. Thinking about the cooling circuit, I'm not sure how the system could ever be pressurized as its drawing water from the sterndrive and exhausting water out the exhaust? Am I missing something here?
Its probably not super important, I am going to be running antifreeze through the system anyways, and can just open all the blue drain points before hand. But I would really like to understand why the pumping method isn't working for me.
Freshwater boat. No seacock and inlet water valve as cooling water is drawn from the sterndrive.
Thanks in advance!
Jim
Thanks in advance!
Jim
Post edited by Squatch68 on
It didn't work when I bought my current boat eight years ago, and I don't miss it.
