Cooling Water Pressure Reading
Installed vessel view mobile on twin 350 mag engines w/ bravo 3 drives. Temps look good...any idea why the cooling water pressures are so different? The engines are raw water cooled. Impellers were replaced in 2019.
For my 496/Bravo 3 powerplants, I'm usually seeing 20-25 PSI at cruise speed. Your engine is raw-water cooled, so mine has extra back-pressure from pushing water through the heat exchanger. But still, 5 PSI seems low.
Take a look at all the parts in the cooling system to trouble shoot. The sensors are probably the cheapest to replace and the pumps the more expensive items.
Take things apart and inspect their condition at the very least when you are done you know exactly what you have on your boat
Definitely swap sensors 1st as @davidbrooks recommends. Very easy 10 minute job.
