Water Distribution Hose Assembly
aero3113aero3113 Member Posts: 9,656 ✭✭✭✭✭
I pulled the boat today. When I flushed the engines I pulled the lower drain hoses off so I can make sure the drains are clear. When I did the starboard side, of course one of the quick releases snapped. Can I just replace the hoses and quick releases and use worm clamps instead of buying a new assembly? The hoses are pressed on now. They are brittle and need to be changed.
