Gelcoat repair
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
This is my jet boat. Foolishly tied it up along a channel not realizing it was banging against a shore power pedestal. Three hours of boat traffic and dozens of little nicks and punctures.
Question is on the small nicks, do I need to dremmel them deeper to do the repair? There is a spectrum repair kit for this which is great, but I’m hoping to not have to dremmel too many of them out first. The lines you see will sand out, they don’t need filled.
Appreciate any thoughts
As bad as that looks, if you can get a color match, it isn't that difficult to fix that, just takes time ... let the gel set properly before you go sanding it.
Also, it looks like some of those nicks went deep and into the fiberglass. Is there any fiberglass damage? You might want to take out any lose pieces of fiberglass, and fill with a bit of epoxy, then apply the gelcoat. This is for two reasons ... you want a fairly sturdy backing under the gel, so it doesn't flex and cause cracks in the future. Also, if you apply too thick of a gelcoat, it will crack. There's an optimal thickness for gelcoat.
lol the admiral doesn’t even like when I pee off the dock!
