Question\Discussion on Charging New house Bank
Current Status: 2008 350 EC with the Inteli-Power PD2040 (40amp) charger, house bank two 27 group deep cycles (Guessing Ah for each at 80). Both batteries are now 3 seasons old. Plus 2 starting batteries that are good. Day on the lake power consumption is radio\amp(40 Amps ), galley fridge (6amps), cockpit fridge(6amps), and occassional use of lights and water pump during each hour (3amps). Total typical usage is 55 Amps per hour at max when radio is on all the time.
Needless to say we kill the house bank to 50% or below in 3 hours, this is a PITA for me since I know I am shortening the battery life and using the generator more then I want too. Because of this I am going to goto 3 group 31 deep cycles on the house bank. At roughly 100 - 110 Ah per batery i'll be around 300 Ah and double my current capacity.
The questions I have are regarding charging the battery banks via the PD2040 charger (whether on dock or genset power) vs the engine alternators.
Questions:
1) How does the charger decide which of the three banks to charge between Star Starter, port Starter and House Bank (how does it allocate its 40 amps)?
2) When the engines are running and alternators spinning at enough rpm to produce charge, they are each rated at 70 amps. Are all 70 amps available say at 2000 rpm? How is the alternator power shared or divided between the battery banks?
With the above answers I can then calculate the mins\hours needed to recharge the batteries based on the amount of discharge they are at.
Note: I am sticking with the flooded wet batteries for now. The PD2040 charging rates for the phases are for led acid wet cell batteries. I believe if I was going to go to AGMs I would also need to update charger.
Questions:
