Cracked radar arch repair
davidbrooks
Member Posts: 1,416 ✭✭✭✭
I know this is a fairly common issue as i have heard others chime in that they have also seen the gelcoat crack on the base of the radar arch. Mine is just on the port side. The outside has a fine spiderweb crack but i am going to leave that for the time being. The inside though actually had chunks that were starting to pop out. I started doing some chipping and i thought i would show you what i am finding. So these arches are galvanized aluminum. It looks like on mine at least it was damaged at some point. The inside has a crease or dimple going in. I don't see how this happened on the boat. More likely in my mind it was damaged prior to installation. Just rough handling with a forklift. Anyway. The main culprit is corrosion or oxidation. Everything that i have read says that after you take the finish down to bare metal you have to coat it with body filler immediately. This is just using a putty knife and rubber mallet. Next up is a sander and steel wool. I need to do a little more research on body filler. I am used to work on fiberglass but i need something designed specifically to be applied directly to metal. Suggestions are always welcome. Bondo and 3M currently look like good candidates. No comments on the mold on the rail for the side panels. That was wiped off right after i took the pic.
I wouldn’t worry about the strength of the filler - it is the bond between the filler and the bare metal that matters.
