350 MAG MPI temp/pressure sensor
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
I pulled my TMAP/PMAP sensor off my port engine to replace it since I was seeing RPM drops when throttling up compared to the starboard engine. The one I pulled out was oddly covered in oil, not gas (no gas smell and it does not evaporate). That cannot be good for it, especially the pressure sender side. Anyone have ideas why this would be oil coated? It is mounted in the intake manifold just behind the throttle body.
Wondering if I should replace the other one too, but they are pricy guys..2 boat units.
Thanks!
If, after a few hours of operation, you pull the pcv hose (from either end) and there is enough oil to cause a single drip (not atomized) oil, it is time to figure out why there is excess positive pressure in your crankcase..
the problem with PCV's, which I'm certain is indiscriminate to applications of engines, is that they are made by the cheapest bidder and there is a metric ton of crap in the market... this is one of those items you gotta purchase from the dealer, unfortunately..
fortunately, though, any GM dealership will work.. it's the crap at the box auto stores that will cause you grief..
there are a lot of parts I will use from those joints, but there is a host I won't.. any of the primary engine management sensors such as IAC, MAP/MAF, CPS, CKPS, o2 (where applicable), IAT, ect... those are going to be OEM replacements, even though they run likely twice the price of the aftermarket items.
there is a simple spring and ball valve in those things that gums up and causes them to stick.. at start-up, there will be some blow by on any engine.. that brief second before pressure equalizes can coat the ball and disallow it's seating over time.. which creates a situation where oil can be sucked right up into the induction process under high vacuum signal situations.. the Asian market make products that skimp on tolerances, which is pretty important at that junction... oil entering the induction can cause a lot of issues, and all because someone wanted to save $5 and a trip to the dealership, ya know?
Ahh, the car/boat cross reference parts conundrum. It sounds like a pretty generic part so If I hit my local GM dealer (who is far closer than my Merc dealer) I'll ask for a GM PCV valve and grommet for an '04 350? I can imagine the blank stare from the car parts kid who only knows parts based on auto model/year. Any idea of an auto application that might be close to set him on the right trail?
I'll be at the boat today and get a pic of the sensor location for you.
http://www.ebay.com/itm/OEM-REPLACEMENT-Mercury-MAP-Temperature-Pressure-TMAP-Sensor-885165-mercruiser-/282068462856
For what is it worth, I bought the Mercury part, not a knock off. Sells for near $200, but at least I know it is 'correct'.
