Transom Coring
I'm in the middle of re bedding the D bolts in my transom and noticed that the coring seems to be made up of two materials. Take a look at lower hole in the attached pic, the material closest to the camera is darker than the material farther away. It is not due to moisture, both areas are bone dry. The upper hole is the same, just not noticeable in the pic. Anyone know what the coring is in a 360 and presumably most other models? Thanks.
By the way, in 2008, I purchased a Mainship 350 from a guy at your marina. Ted Patrick was the broker. Trip back to Georgian Bay was lots of fun.
Thank you.
