Cooler size ?
I have a 2008 276BR and am looking for the cooler size that goes inside the sink cabinet on the starboard side just behind the drivers seat. any one with another 276 can advise?  Thank you in advance
    Confident it's a Igloo 36 quart marine hard side cooler. They were the common size cooler that Rinker included with a lot of boat models.
    FYI: Igloo Marine 36qt measurements are 22" wide, 13" deep, 13" high.
    Igloo Marine makes some really nice soft sided coolers now. Bit more handy than the hard side models. Easy to load & unload into cabinets.
    I still keep a hard side cooler on board for big events - full of ice only.
  • rasburyrasbury Member Posts: 8,776 ✭✭✭✭✭
    Lots of folks have re purposed that space for storage...
  • FeelinNautiFeelinNauti Member Posts: 14
    Soft coolers are a good idea, thank you.  There is a ton of storage on this boat but sadly no where to conviently put a cooler thats out of the way. we use the bathroom locker for bigger items that need storing, would be even nicer to kook up a small 12 volt cooler under the cabinet as well if that existed.
    @FeelinNauti on our 276BR we used to slide the 36qt cooler up the walkway in the bow….under the bow filler cushion.
    Soft coolers in the cabinet.
