Dash panel light. Capable of adding a dimmer?
Hi.
I have a 2005 232 BR.
At night the gauge cluster lights are so bright I have to throw a towel over the dash.
I haven't tore into it, but thought I would be smart for once and ask if anyone knows if a dimmer can be added to the circuit? I don't know if full current goes through the switch or if the switch goes to a relay, etc.
I am hoping it is as easy as adding a rheostat between the switch and the lights.
And no, my light switch does not have the dimmer function. It simple toggles off and on.
Thank-you for any input.
Hey gslpro are you the same glspro from the old RBO? Welcome to the RBOC...
Thank-you, all, for the input.
My switch is on/off only.
I will check with Rinker parts to see they can sell me one that matches.
it's buried with Jimmy Hoffa you'll never know
