FV 242. Plumbing and gas tank vent?
JohnChurchillJohnChurchill Member Posts: 6
New to me ‘99 FV 242. Trying to figure thru hulls out.
There are two low on the port quarter and one low on starboard. What are these?  I assume one is bilge.
Where does shower drain?  Too low to go directly overboard.  Bilge or holding tank?
Small plastic thruhulls by waste and water fill I assume are their vents.
I don’t see a vent for the fuel tank.
Thru hulls- port forward is galley sink. Starboard forward are 3- bigger one is sink drain. I assume smaller lower one is head intake. What’s the third?
Sorry about crooked pics
Best Answer
  • aero3113aero3113 Member Posts: 9,586 ✭✭✭✭✭
    edited January 2022 Answer ✓
    Your fuel cap assembly is vented
    The lower drains (LH/RH) in you first pic is for the engine hatch water channel.
    The third in you last pic is for mid bilge shower sump pump. It’s located under the steps in the cabin. I believe there’s a bilge pump in that area also.
    I’m trying to remember from when I had my 242.
