Air conditioner issues
So, this one is a bit strange and started last year. I have a 12kbtu until in the back and 16k in the front. When I'm on shore power, all work great. When I'm out on the hook, and running generator, the 16k front unit has a startup issue and restarts when, I think, the condenser starts up. Maybe it is drawing too much power? But, the generator seems fine and no breakers blow. Last year it would take a time or two and then be ok. This weekend I could not get the front to work. I believe, not positive, this has only been with heat. No sure though. I also noticed at times when I first start it that the temp on the panel is way off. Usually lower, but it changes quickly within a few minutes. Thinking about it, I know the temp change is also with ac, not just heat.
Any ideas? Everything else is fine on genny and it runs nicely. I'm actually ok replacing the dam thing, because it's original and I'd love to have one with fiberglass pan and quieter. But, the engineer in me wants to figure it out. I have some pieces like a display and electronics board from a friend's old unit I can try first. Just seems odd that it works fine on shore power.
Luckily the back unit and a small electric heater was good for the night.👍
Also, if I buy new, what are your recommendations? I remember some nice ones people where getting over the last few years.
Highly recommend, very quiet!
Heres a link
https://www.marinaire.com/Products-s/12.htm?gclid=CjwKCAjwo8-SBhAlEiwAopc9W6C3VddACn38C0xdKompSUnfFiihcHbTm_E3N3BAEOEK51XW_wG9ERoCxKsQAvD_BwE
@raybo3 it does seem to happen when blower tries to start.
And yes, that one that Aero bought is the one I was remembering!
Oh, and @Grahamu, you are right, comparing those two are a good and easy check.
