Mercruiser 377 MAG MPI overheating with Guardian (2014 260 EC)
                    I'm at my wits end. I'm really hoping someone can help me.
I bought this boat a year ago and it has been one issue after the other. The biggest issue I have had is the over heating issue. It only overheats when approaching 4000 RPMs for 15 to 20 minutes. Guardian kicks in and I have to throttle back. Staying on idle does not cool down the engine. I have to take it 1500 RPMs to increase water flow and then it will cool back down. Temp reading is around 225' when guardian kicks in. Four mechanics have looked at this and each one did something different.
Here's what's been done so far:
New water pump and impeller
Heat exchange flushed
Lower unit intake inspected
Hoses inspected
O2 sensors replaced
Not related but also performed:
Fuel pump
Steering pump
Gas tank
Cap and Rotor
I have found two discussions online regarding this issue.
One indicated to replace the Engine Water Pressure Sensor (881879T11). Ordered this.
The other is an issue described as Bravoitis. Definition from Offshoreonly: "The crushing of the forward end of the water hose and retainer of the belle housing to transom plate water hose, which will restrict water flow into the sea pump with a severe heat increase in the pump from friction and causing rubber impeller failure." I did have the lower unit removed during the gas tank replacement this was noted by the mechanic but I'm not confident he knew what he was doing.
Really hoping for some feedback from the community.
In addition to the over heating issue, Vessel View shot out an alert stating: Catalyst Oxygen Storage detected a fault.
This didn't stop the motor from working and alerted hours before the over heating.
Thank you
Hoses inspected
O2 sensors replaced
Fuel pump
Steering pump
Gas tank
Cap and Rotor
Thank you
There is a raw water pump and a heat exchanger. I think this makes it seawater cooling.
I'm assuming your boat does not have the "dual pickup" plumbing, with a second thru-hull water intake with a strainer.
To replace the intake hose, I see that the lower unit must be removed. Is this right?
Has anyone tried installing a through hull instead?
Thanks.
I replaced a water pump already. Is there more than two?
No water leaks in the bilge is visible.
When properly maintained, the Bravo 3 provides enough cooling water for up to 425 HP. The dual pickup adds more points of failure that could sink a boat. It adds more complexity and more things to service. And I always had trouble getting my water pumps to prime after launching in the spring.
He suspects its the riser manifolds. This is a pic on the starboard side when the motor was removed last year.
What do you guys think?
Since you have closed cooling that takes a lot out of the picture. Our 270 closed coiling has the dual pick ups. I replaced the transom asy and with the motor out did replace the risers and the elbows- but the manifolds are coolant only so not a corrosion issue.
Overheating a motor is serious stuff. Mine did and toasted the flappers in the exhaust which could allow water to flood the motor through exhaust. Inspect the plugs/cylinder for coolant? Engine oil? I figure overheating on a motor almost like a person having a fever- you have to figure it out! Thermostat? Could be simple...pull hoses or feel if water is moving? Two pumps, one for coolant and one for raw water to cool through the heat exchanger. I'm not sure on my dual if the bravotitus got it that it would not pick up enough water through the thru hull to keep it cool...
