Bravo 3 no foward gear.
Picked up a 2000 Rinker Fiesta Vee 242 with a Mercruiser 5.7 EFI Bravo 3 drive. Tested it in the water for a half hour in November with no problems before winterizing. Just went to take it out for the first real cruise, backed away from the dock, shifted to forward and nothing. Drive goes in and out of reverse no problem, The cables on the engine move when shifting into forward, but no forward gear. Any ideas would be appreciated.
No, the outdrive was left on, and I disconnected the cable at the adjuster and moved it all the way and still could not engage forward gear. More discouraging news, I just pulled the outdrive off and the driveshaft bellows are full of rusty water, the u-joints are rusted, and the bearing inside (gimbal bearing?) I could not turn by hand.
You can open the vent on the drive, and insert a telescopic magnet, and see if your gears are chewed, evident by chunks of metal. Also, and at the same time, you can inspect the gear oil and look for milky appearance, suggesting water infiltration..
These two circumstances aren't necessarily related.. it just suggests the prior owner may have been lax on maintenance.. it could be as simple as a broken shifter seat thingy, which I'm pretty sure is the proper name for that thing. :-) ... It's where the cables connect.
You're still gonna have to address the bellows and bearings... But this doesn't mean your outdrive is toast.. it may just mean the mechanisms, specifically the throw out lever (again, a made up name) is corroded and also needs replacement.
Best of luck, man.. I'm sorry to hear of your troubles.
Can you turn the prop while lever is in gear and see input shaft turn?
The outdrive fluid looks good, dark blue with no sign of white or milky colors.
Thanks for all the help, the problem was the shift cable! Wear, or contact with the driveshaft wore a hole through cable housing, so when I "pushed" the cable to engage forward, it would push out through the hole. Again thanks for the help.
Not cheap, but a lot better than a blown drive. I had my fingers crossed for you! :-) MT
