280 EC - Sink Drains and Leak Hunting
mvgvb
Member Posts: 46 ✭
Hi All,
We bought a 2008 280 EC last summer, and have now been hunting down a leak into the aft berth on the starboard side by the A/C unit since last year.
It's definitely tied to the fresh water or drainage system, and I seem to have it narrowed down to either the fresh water lines (after the pump when the water is routed towards the head) or the sink drainage system. Ran the cockpit sink for a while today and couldn't figure out where it's draining to. Where do the cockpit, cabin, and head sinks normally drain to in a 280 EC?
Just occurred to me today that we bought a lake boat (and moved it to the ocean) and I'm wondering if we are dealing with drains that have been intentionally clogged or re-routed due to grey water regulation, but curious where they would usually drain. Overboard? If so, to separate drains or all to the same?
Separately, any advice on how to get into the wall on the starboard side of the 280 to where all of the plumbing for the head and the A/C unit is?
All the plumbing for the head is earlier right next to the pump handle which you can see visually or under the mattress. You can remove the cover over the AC unit at the foot of the bed if you need to access the hoses at midpoint.
@Cableguy Greg I did check cockpit sink and didn't see anything draining out the hull. I traced the cockpit sink drain, and it actually heads down to the engine compartment, across to the starboard side of the boat, and then heads forward behind the area with the A/C. Couple questions:
@Cableguy Greg @Aqua_Aura On the shower sump under the aft berth - looks like there's 3 hoses. I assume the large, white hose coming from the direction of the head, is the shower drain? The hose by the pump is the one pumping out, what's the hose coming in from the port side (bottom of the pic)? Any chance it's the galley sink?
I opened the A/C wall opening and reached in with a camera to see if I could find anything. Looks like there's another sump box behind the A/C unit... very inaccessible and I can't tell what's going on there. Any ideas?
I'm not certain yet, but I actually think one of those black hoses going into the box may be coming all the way from the cockpit sink.
it sounds like you guys may have more thru-hulls than we do, also based on google images.
I have 3 on the starboard side by helm. One is for the A/C, not sure about other two.
I have one on the bow, starboard side, for the anchor locker drain.
most pictures I see, there’s at least 4 on the starboard side by the helm, and usually on towards the stern on starboard as well. Also usually one on port side mid-ship.
Can you guys confirm mines different from yours? Think Rinker made a fresh water version of the model?
On Port I have two one for each sink overboard
On port I have one forward which is galley sink, one midship which is cockpit sink, and one aft which is bilge pump.
Ignore the scum line, these were pre-cleaning!
Nice trailer @Squatch68
I don’t have the 4th, or the head drain one, or the galley sink or cockpit sink drains. I assume my 3 in the grouping are AC, Helm Drain, and mid-ship bilge.
@Aqua_Aura I liked your idea of forgetting the current setup and just starting fresh routing to the original placement. Doesn’t seem like that’s an option anymore. Any other ideas? Is it possible use hose splitters and route two separate drains to a single thru-hull?
