Water Heater.
Im hoping that someone on the group can confirm something for me.......pretty sure that know the answer but I'f I'm wrong , its gonna be an expensive mistake. So.....I have an Atwood water heater that is dual electric and engine heated. I suspect the heater is leaking so I've drained it and I'm going to bypass it til I can confirm whether or not thats where my leak in the engine room is coming from. Is it OK to run the engine without water in the heater. Is there any chance that the heater could overheat if its empty. I'm assuming that the way the heater works is via a "heat exchanger" so I think I should be OK......Thanks for any help with this.
