Ground block - 2003 FV310
Member Posts: 3,014 ✭✭✭✭
I think the root of my issues last week is a connection problem at the common ground - great run out today on plane and speed a few times then last throttle back to come in and alarms going off, low voltage again. Has to be a ground, only common connection.
I have to go a hunting but anyone know where the block is for the batteries? @Pat310 @Rinker310_LI @rinker310FV @rinker310 - you guys found yours?
After finding nothing with grounds I watched my DVM as I hit the key and the voltages dropped way low and each starter did the same, switching batteries to emergency start didn’t help. Got jumper leads I have and hooked one to the house battery and it fired right up, same second engine. Now I was sure and arranged 2 new flooded 1000MSA batteries.
Borrowed a fancy analyzer and sure enough - came up bad with MCA on one 17 and the other around 80 - for 750 MCA batteries. Also tested the new ones - right from store and got 1280 and 1285 MCA readings. Put in the the engines crank over at a rate not seen for a while.
Shame I paid a lot for the AGMs, expecting more than 3 years of life and questioning if perhaps a a bad batch of the group 34’s as the 31 house is fine.
Lesson learnt - don’t assume the “can’t be” isn’t!
