OIl leak?
Hello all, I have an oil leak dripping from under my 2005 5.0 Mercruiser MPI it almost looks like its coming from the front area of the pan and dripping straight down but the pan itself is dry. Is there a common area or item that leaks in that area? I've looked everywhere and cant pin poiunt where its coming from. Oh ya, it only leaks when it runs. What do you think? Thanks, Marcdohc
How much patience do you have?
Taking the pan off is a matter of minutes on a stand.. prepping and new gasket another matter of minutes.. it would likely take at least two hours to get engine to a stand...
Leaving it mounted, and you'd only need it to drop a couple inches at most, it would likely take a couple hours to get it off, half an hour to prep, and another two hours to install... But, you could do it yourself and not have to pay a lot of labor costs..
Hint to making it easier: use fishing line to align and hold the gasket to the pan while trying to install.
After Aero posted his oil pan leak issue last year I went looking at mine. Here's what I found....and the fix. I caught mine before it failed along with a mandatory engine pull. A host of cell phone pics to check my work, a dremel with a wire brush head, some pretzel time in the engine compartment and some rustoleum saved mine. Hope it's an easy fix for you.
JS, I've been wondering too. Ill ck and post an update.
