SO say someone used an impact gun to tighten down the nut on the forward prop of a B3
Don't ask me why this happened, but it did. After putting all of my weight into a 1/2 inch breaker bar and almost breaking it, the thing is STUCK on, even with the help of oil.
My questions-
Could any perm. damage have occurred?
Is it okay to use the impact gun to get it off?
Dam that saying about "you have to do everything yourself" keeps biting me in the rear over here!
My questions-
Post edited by raybo3 on
I have already have new nuts, would never reuse them..
I called a local towing company who came out with a 700 dollar electric impact gun and he had this done in less than 30 seconds.. for the first 15 seconds it was working HARD for sure..
I plan to put the new 22p props on and use the correct torque bar to put the rear to 100lbs/ft and the front to 60lbs/ft. Is there anything else to do? there does appear to be plenty of grease on the shaft splines, should I put anything on the threads ?? Didn't see any corrosion or any other reason that this was so hard to get off.
I can't believe that he used an impact and a breaker bar. WTH? I wouldn't want him working on my boat again. What else does he over torque?
