Engine hatch won’t open
After all going well with our new to us 2005 FV, yesterday the engine hatch wouldn’t open. I could hear the lift motor working when I hit the down toggle but nothing on the up side.
After some pondering I started the engines and waited a few minutes … success!
So I’m going to assume, without digging into schematics, that the lifter is run off the starting batteries.
At the time it wouldn’t work I had the Shore power connected and the battery charger turned on. I checked the battery charger and the lights indicated it was working. As I recall, I had raised the hatch using no batteries, just Shore power and the battery charger when it was on stands and I was inspecting it.
How would you address this problem?
It's curious that your motor would move down but not up.
Batts are good for 3 seasons - after that, any additional years are a bonus.
Generally, the only critical setting on chargers is the battery 'type'. If not set properly to Lead Acid, AGM, etc, that will definitely shorten batt life.
Smart chargers - charge at different rates based on setting type.
@AtlanticJim keep us posted.
When I did my reno, I added a second terminal block. I cut each wire back to get fresh copper, and installed a heat-shrink ring terminal. I put no more than two ring terminals on each screw.
Even if you don't have a ground issue yet, it's good preventive maintenance.
