Low water pressure, but no overheat
pcmpete
                    Member Posts: 114 ✭✭
                    Mercruiser 377 with bravo 3
engines ran great for approx 1hour.
Dropped anchor for 2 hours
on my way back to my dock in ‘no wake’ I noticed my water pressure on starboard engine was very low at 2.1psi
i went to idle and continued on.
then psi slowly dropped to 1.2psi,
so I decided to find the nearest dock and call TowBoatUs.
I have closed cooling, and the engine  temp only rose to 171f (normally runs 165).
I had new seawater pump and impeller installed approx 1 year ago.
would the impeller be shot already?
I thought maybe the water intake got blocked. I visually checked it back at my dock.
After about an hour after I got towed back I started the engine to see if any change, but no. Pressure was only 0.9psi at idle.
no alarms or warnings.
what and where should I check first?
thanks guys
thanks guys
FYI, the voltage is a bit low on both your engines, but especially your stbd (12.5). I'm assuming the motors are running since you have water pressure.
Even a brand-new pump and impeller could get chewed up in a few minutes if you suck up a bunch of sand. I'd run the engine briefly up to 2500 RPM in neutral, and see what the water pressure does. Do the port first to see what "normal" looks like, then starboard.
Pressure is low at idle but normal at high RPM: worn impeller and/or pump body.
Pressure is low at all engine speeds: intake restriction such as a plastic bag sucked into the intake on the Bravo.
I know my sea pump housing is scored up and is probably cavitating at cruise speed.
I just changed out the Port Sea pump but haven't got a chance to take it out yet.
Attached is the error before pump change, and pic of gage when running as alarm went off. Port engine coolant temp would creep up after 5-10 minutes and alarm PRT EMCT OVRHT would trigger.
