Fuel capacity & range for 2005 342 Fiesta Vee with twin Merc 350's
I'm planning a trip the end of August from Put-in-Bay, Ohio to Sarnia, Ontario and I'm trying to find out what my fuel capacity and estimated range would be. I dont have my owners manual with me and I've seen fuel capacity listed at 180, 200 and 230 gallons respectively and I wondered if anybody knew which one was correct and what my range might be?
You should hold 235 gallons total. Range will vary from boat to boat, sea conditions, speed, etc. My 2003 342 with 350 MAG MPI's..I burn about 30 gal/hr at a reasonable cruise ~27mph (aound 0.9 mpg)
If you have charts or plot a course on GPS/chartplotter you'll know the miles to go very close. Then you can see where you'll need to stop for fuel, if at all. A nice rule of thumb is to leave about 1/3 of your fuel as a reserve, just in case.
Enjoy your trip!
Now waiting for RY to chime in about diesels....
Andy
Jillicious,
I would agree. Using 30 gallons per hour and the 1/3 rule, you are at 140 miles so you should be good.
Have fun!!
Garmin has a great set up for fuel flow. Should check it out before you drop a dime on the lowrance.
