New fuel senders
davidbrooks
Member Posts: 1,418 ✭✭✭✭
I thought i would open a new discussion on this topic. We started a previous one and @LaRea made an interesting comment when he said that the OEM senders just read in 5 increments. I have been having some flaky experiences with my setup so i had been looking into a solution. Well, this weekend it rose to the top of the priority list. I was taking the boat to the marina to start winterizing and ran out of gas. I was about a mile away when i ran out.
Called TowBoatUS and waited to have them come get me. If you all don't have a towing service i recommend it for peace of mind. I have had this since 2018 and never had to use it. My fuel senders are original. They are just an analog resistance sender that is basically a rubber ball on an arm. The sender is wired into both power and a Garmin NMEA 2K device. The setup has been problematic since day one. Getting it calibrated...keeping it from just dropping out of the system...you name it i seem to be fiddling with my starboard tank setup all the time. I didn't have a long run, havent used the boat hardly at all this year. So, i figured i would just rely that the one sender that was working had an equal amount in the other tank ~ 30%. That assumption got me about 85% of the way to the marina.
Tied up to the fuel dock for the night and put 20 gal in each tank. Took a while for the engines to get primed but they thankfully started right up. I pulled out the icemaker and fridge to get to the starboard tank. BTW on a 2003 342 they put in 117 gallon tanks. For anyone in the future that wants to know they are Florida Marine Tanks, FMT-117P-RKB 117G/442L Part number 240126.
I am going to put in NMEA 2k senders. I ordered Oceanic Systems NMEA 2000 Fuel Tank Volume / Level Sender - 1000mm - 5-Bolt SAE from defender.com. Link here. I am interested in if anyone can find any bad reviews or has any warnings for me. I looked but couldn't find anything.
The reasons i settled in on these are: 1) reputation 2) all one unit 3) no mechanical arms 4) can be shortened and calibrated on site 5) have up to a hundred increments vs 5 6) they also will sense if there is water in the tank.
The plan is to shorten the pickup tube to 24 inches. The tank is 28 inches deep and i can assure you the pickup tube goes all the way to the bottom. When i put in 20 gal i measured 4 inches of fuel at the bottom of the tank. I figure if the sender is reading empty i can still have a few miles left. It may take a while for them to come in though as all of the sites say they are backordered.
Why? You can't rely on the reserve unless you know when the gauge start reading zero. Suppose you look down and notice the gauge says zero. When did it hit zero? Do you have actually have 20 gallons left, or are you empty?
In fact, I'd argue that when you're down to the last 20 gallons, that's the most important time to have accurate measurements. I wouldn't discard that information.
