Lifep04
I'm thinking of replacing my 2 house batteries with 2 lifep04 batteries. I would
program my pronautic 1250 charger to bulk charge at 14v and float charge at 13v. I would lose some charging efficiency, but this would allow me to keep my 2 sealed flooded lead acid start batteries. I know it is not recommended to mix battery types but since each bank will be of a consistent type (2 banks of lead acid starting batteries and a house bank of 2 deep cycle lifep04s), I think this will work. My question is what happens if the battery management system (bms) on the house bank shuts them down while the engines are running. Will this be a problem for my alternators which are not externally regulated. I have a promariner 2 70 3 battery isolator. Thanks.
https://rinkerboats.vanillacommunities.com/discussion/comment/174193#Comment_174193
Two Victron Lithium 200ah with the BMS 12/200 and the ARGO FET isolator would probably work great for you. I would leave the ProMariner to do only the starter batteries and add a Victron 120v charger for the Lithium.
I am really happy with the Victron stuff; it's not cheap but it all works well together.
