Jabsco spotlight troubleshooting -- moves up/down but not left/right SOLVED
LaRea
Member, Moderator Posts: 8,001 mod
[EDIT: the problem was a failed motor. See solution at end of this thread.]
It has been a while since anybody complained about their Jabsco 62026 spotlight, so here goes.
Bulb lights up
Light moves in pitch (up/down), but not yaw (left/right)
Components and connectors all look fine by visual inspection
I took off the housing and swapped the two wires that go from the circuit board to the motors. [CORRECTION: Then the motor would move in pitch when I move the joystick in yaw, but would not move in yaw.] Then the light would move in yaw, but not pitch. That rules out the yaw motor and gears.
The only other possibilities are the joystick and the circuit board, right? Neither of those is cost-effective to replace on a 15-year-old spotlight.
Bulb lights up
Post edited by LaRea on
I see remotes on eBay for $300, but I'm not sure that would fix the problem.
They really are ugly, especially after a few years of fading. But you'll find this same cheap, ugly remote on $1M+ yachts. It defies logic.
For reference, here are the pinouts on the back of the Jabsco controller. Going clockwise from top right:
1. Light (motors at fast speed)
2. Light (motors at slow speed)
3. Right
4. Up
5. Down
6. Left
7. Ground
I have leftover parts: a motor, a motor controller board and a nice shiny housing. You want 'em, they are yours. (The gears are not usable.)
Here's how to troubleshoot the motor controller board:
The board has a large 4-pin connector (left side in this photo). Get a 12-volt battery or DC power supply, and connect the + and - wires to pins 1 and 2. One of the motors should move. Now connect to pins 3 and 4. The other motor should move.
Replacing the pitch motor is easy -- three screws and it pops right out. Replacing the yaw motor is harder because one of the screws is covered by the big white drive gear. Removing the gear requires a pair of snap ring pliers, a screwdriver, and a careful hand so you don't drop any of the little fasteners.
