Silly shore power question
brianflhrci
Member Posts: 62 ✭✭
I've got a 2003 FV 290 and it's my first modern cruising boat. My question is do I need to turn off the shorepower breaker when I unplug and take a ride? Also, I don't have a generator, will my fridge run on the house battery?..or what do I do to make this work?
Thanks,
Brian
Its good practice to turn off the power before unplugging or plugging in your power cord. Most likely nothing will happen however there is a chance of the power arching and causing damage or electrical shock if you are wet. The refer will switch to 12v automatically.
LG
I always switch off the individual 110 V breakers (fridge, charger, etc.) then the main 110 V breaker, the the shore power breaker, then the shore power switch to off before I unplug the main to the dock and finally the cable into the boat.
This avoids a surge during disconnect damaging any equipment. Also you have to make sure that shore power cable doesn't damage anything if it is accidently dropped in the water. So that is why you isolate everything inside the boat first and then unplug at the dock. If it drops, technically everything is isolated. If you unplug the boat first and drop it in you have a 110 V surge into the water (galvanic damage).
