Pre-start checks
Hi everyone.
I will be picking up my (new to me) boat on Sunday. It is a 2003 Rinker Fiesta Vee 250. I've driven many speedboats but this is the first time I've personally owned a boat, (and this one is a lot bigger) so I've never had to worry about pre-start checks. Here's where I could use your help:
Seacocks - where are they and which ones should be open/closed?
Switches - battery charger switch on & shore power off. Should all of the other switches be off?
Blower - run for 4 minutes before starting and until planing. Should the blower remain off then or should I run it whenever I'm not planing or when refuelling?
All of the survey recommendations have been actioned over the last few weeks and I'm told its good to go.
Thanks in advance
  • YYZRCYYZRC Member Posts: 5,356 ✭✭✭✭✭
    Congrats!
    I check the bilge once every two weeks minimum - quick look at belts, check for water/fuel/oil leaks, check oil level and power steering fluid level and trim fluid level, check freshwater and poop tank levels.
    I leave all seacocks open (AC and generator).
    I leave all switches/breakers on except the generator DC power switch.
    I use the blower always except when on plane. Always off during fuelling.
    Let’s see some pics!!
  • aero3113aero3113 Member Posts: 9,545 ✭✭✭✭✭
    edited January 2023
    Congratulations! @TickledPink
    While under way your battery charger will be off, the batteries will charge via the alternator.
    Your shore power switch will need to be on for your battery charger to work when you’re at the dock.
    some people run the blower at all times of use, some only before startup.
    how many seacocks do you have and do you know what they are used for?
  • TickledPinkTickledPink Member Posts: 103 ✭✭
    Thank you @YYZRC and @aero3113
    I feel less apprehensive now. Also pretty excited.
    I don't know where the seacocks are. I just know there's one for AC sea water coolant inlet and one for the toilet waste holding tank outlet.
    There's also a toilet inlet and a engine coolant inlet, bilge pump outlet, vanity, galley and cockpit sink outlets, shower waste water outlet, AC coolant outlet. I have no idea if these have seacocks.
    You likely only have a seacock for AC inlet and toilet inlet. If you have closed cooling you might have an inlet for that (in the bilge).
    The sink outlets and shower outlet likely discharge overboard unless you have a grey water holding tank. Bilge and AC discharge overboard for sure. No seacocks for discharges.
  • MH342MH342 Member Posts: 73 ✭✭
    When casting off …
    - fill freshwater tanks, monitor pumpout tank.
    - blowers are a must except when fueling, they should be off to avoid pulling in fumes. I leave mine on all the time because once I’m on plane you can’t hear them anyway. If you can hear them, replace them.
    - I usually throw the main shore power breakers when departing. Also, unplug the dock side first so you don’t have an energized plug that can fall in the water.
    - battery config varies significantly boat to boat. In general, leave them in single mode … ie not “both”.  I never touch mine unless there is a problem.
    - working safety equipment and that any visitors know where life jackets are, etc. Also have a throwable.  Most of the drownings on our lake happen while swimming and may have been prevented with one.
    - Remove shore power and all lines before casting off :) … it happens.
    - at night make sure all lights are working properly.
    when leaving the boat unattended …
    - Disconnect city water (if it’s available at the dock) when leaving the boat unattended.
    - I usually turn off all unnecessary breakers leaving just fridges and battery chargers on both AC and DC panels.
    - if you have vacuflush, find a way to turn off the pump when the boat is unused.
    - I don’t touch seacocks. In my last boat, I closed the A/C seacock because it was aftermarket and I didn’t trust the hose used by the PO.
    - close canvas, check dock lines, check fenders.
    - flush some fresh water and powdered laundry detergent in the head … helps prevent smell.
  • rasburyrasbury Member Posts: 8,703 ✭✭✭✭✭
    Nice looking boat, congrats! I have a 270 so we have very similar laid out boats. I've had mine for several years and I think I could pull all my posts and write a "how to fix your boat" as it seems I've been through every installed component to fix something. I assume you have a 350 gm/merc motor with a bravo III out drive? Great set up- only motor related issues has been the cooling pump which there are a couple of set ups. I have closed cooling so I'm pumping water from the foot and a thru hull right in front of the motor. I also have a generator so I have another thru hull for that. Make sure they operate properly as if you find you need to turn it off and it's froze up, well not good. Your other thru hull for your a/c inlet should be right behind your stairs to the below area in the midship area...also a screen on that inlet,  check that every now and then.
    I had a transom leak and had to pull the motor and rebuild the transom asy- I learned in the process there is a hundred friggin places boats can leak which is a little un nerving if I think to much about it! I had a hit and miss interior leak I chased since we bought the boat- finally figured out the previous owner drilled drain holes in the underneath dry storage seat aside the helm- rare occasion it got water in it- no where to drain except to the mid ship area so previous owners expertise or lack there of can be an issue!
    Good luck and throw the questions.  I never leave the dock until the engine is up to temp and stable- you do not want to overheat that motor.
  • LaReaLaRea Member, Moderator Posts: 7,920 mod
    It's a good practice to sniff the exhaust from the engine room blower before starting the engine.  I do it every time I get underway.  Blowers on, then I walk back to the transom and stick my face down into the exhaust.
    Obviously, you're checking for gasoline fumes.  But after you do it a few times, you learn what "normal" smells like in your bilge.  Any unusual smell (oil, coolant, etc.) should be investigated.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,802 mod
    Welcome to the forum!  A 250 is a great size boat to enjoy for everything!  The first boat I owned was a 240.  We would do everything from 10 day trips on it to a day water skiing.  I even slalomed behind it. Seacock for ac and head will probably be under aft cushions.
    We've picked up the boat and we are extremely happy. 3 hours to get there by boat, bus and train then a 3 hour trip on choppy waters to bring the boat home.
    Totally knackered but still smiling.
  • PickleRickPickleRick Member Posts: 4,213 ✭✭✭✭✭
    Have you ever owned/used a marine toilet system before?
    If not a few notes.
    Make sure it has a vent filter on the holding tank.  Make sure that vent hose isn't clogged.  Replace vent filter if you don't know when it was changed last.
    Replace the joker valve before use if you don't know when it was replaced last.
    Make sure you're entire crew knows feminine hygiene products and personal/baby wipes do not go into the toilet unless you want to intimately aquatinted with the tear down of the marine head.  If it's not proper marine tp or doesn't come out of the lower half human body in a natural way, it doesn't go in the toilet ...ever.  repeat these instructions to anyone who visits the boat.  Not following these simple instructions can ruin an otherwise perfect weekend...many here can confirm.  I keep a large amounts of disposable bags on the bathroom counter for disposal of any items that are not allowed to be flushed.    My mother in law who I love very much, an vacation with every summer is not allowed on the boat any more due to her inability to follow these simple instructions.
    Toilet paper use needs to be kept at a minimum.
    Try to pump the head as often as possible. I find if I pump weekly even in the hot humid south she stays fresh locked up under tarp in 90 degree heat for 5 days.
    Also:
    Also, damp rid is your friend.  Keep it open when you're not on the boat.  No moisture, no mold, no hassle.
