Water in my trim
rasbury
Member Posts: 8,835 ✭✭✭✭✭
I discovered a crack in my reservoir and the fluid is now a really pretty pink color- so probably not a lot of water but I need to clean it out.
I ordered a new reservoir and I ran the pump and blew it out of the top end.
I was surprised that with the OD trimed up, when I released the lined I thought the drive would have lowered with no pressure and I can't move it by hand. I read there may be a reverse lock and a lock release valve but I don't see it on my rams. I did not want to remove the lines from the rams but I guess that is next...if that allows me to cycled the rams to blow that crap out I can get some new fluid in it and cycle a few times...should that be good? I can blow air through the lines and clear those out but I'm concerned why I can "release" the rams not being connected to the pump?
Most likely your seals are leaking on your trim arms aka rams
Lucky for for you, they are easy to repair and should be plenty of YouTube videos to walk you through repair procedure.
The hardest part is getting the cap unscrewed. There is a special spanner wrench to get the cap off, although I used a more crude way to get them off.
It's mostly just some o rings and a few seal washers.
